Author Topic: What liquid flux to use with Bon Pen?  (Read 1758 times)
Offline zaptaTopic starter
« on: September 07, 2015, 03:58:46 pm »
I ordered a Bon Pen and need to get liquid flux to fill it. What kind should I get, no clean? rosin? RMA? RA?
So far I used the ChipQuik tacky no clean but it is too thick for the Bon Pen I presume. I also has a felt pen with Kester 981 and it kind of works but the flux feels weak.
If I get a rosin based, what happens if I don't clean it perfectly, for example, under the components? Will it corrode and damage the board?
This is for hobby use at home. My components are typically new, I use leaded solder and I clean with IPA. I want to have just one kind of flux, even if it is a compromise.
« Last Edit: September 07, 2015, 04:01:05 pm by zapta »
Offline ConKbot
Re: What liquid flux to use with Bon Pen?
« Reply #1 on: September 07, 2015, 05:48:16 pm »
RMA flux is good for applications where you might not be able to clean it. RA is a little too active/aggressive.
« Reply #2 on: September 07, 2015, 06:35:59 pm »
Does this look good?  I need only a small quantity and this US seller seems to be legit.
http://www.ebay.com/itm/141250481358
