Author Topic: should the LTC1043 voltage divider circuit be buffered?  (Read 2888 times)
Offline SArepairmanTopic starter
  • wannabee bit hunter
« on: June 14, 2014, 12:21:05 am »
How should I look at the LTC1043 voltage divider circuits (divide by 2, etc) as a voltage source? what kind if impedance can it support?
how is this analysis done?
I figured something like 600 Hz oscillator frequency, 1uF charge on capacitor, 10k drain, so essentially the capacitor is losing X charge per second and it is restoring itself to full every 1/600th of a second? So its just a RC ripple that changes depending on load?
« Last Edit: June 14, 2014, 12:39:35 am by SArepairman »
Online T3sl4co1l
    • Seven Transistor Labs
Re: should the LTC1043 voltage divider circuit be buffered?
« Reply #1 on: June 14, 2014, 12:37:13 am »
The output impedance is roughly Rds(ON) * 2 + Xc.
Seven Transistor Labs, LLC
Offline Andreas
« Reply #2 on: June 14, 2014, 05:07:55 am »
Hello,
If you want to use it as precision device you should never load the output.
Even the input bias current of a standard buffer amplifier creates a large error.
Usually a LTC1050 buffer (10pA bias current) is used together with the LTC1043.
With best regards
Andreas
