New project, i want do build a battery discharge tester for single cell testing.
Specs:
-voltage range: 0-4,5V (full current sink should be available down to 2V, maybe 25-30A down to 1V if possible)
-current range: 50mA-75A (would be cool to have an universal setup that can either test an AAA NiMH battery for capacity and really push smaller Li-Ion -cells like 18650, 21700 and 26650 to their limits.) Should be able to switch off the current flow so the battery in test doesn't get overdischarged.
-data logging via a arduino and a computer (because i can't do proper uCs yet)
-temperature measurement and cutout
-input should be floating so you can test an 3,3V earthed powersupply with an earthed data logging/showing computer.
I never layed out an PCB before and have small electronic design experience (hey, i built a lab power supply with 2 LM317
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
) so i may ask some rather dumb questions down the road when I'm at the board layout stage. But eventually I end up with a nice battery cell tester and share my design which may is helpful to anyone
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
For now i did search for components and started with the schematic, next up is ordering the parts and doing some breadbording as well as figuring SPI out. Then think a litte about decoupling and component values and finally layout.
