Author Topic: Serial port in C in windows works only after using terminal program  (Read 2017 times)
Offline jmajaTopic starter
There is something strange I can't figure out. Maybe someone can point the obvious mistake I'm making. I'm trying to read lines of serial data (100-110 bytes/line ASCII at 10 Hz at 115200) from my SAMD21 board via USB virtual port in Windows 7. It works just fine, IF I first open the port in e.g. Tera Term (even with wrong baud rate etc.) and then in my program. But if I don't use Tera Term after pluging the USB, I get no characters reading the COM port. No errors either.
So what does Tera Term do that I'm not doing to enable the data flow?
Here is how I open the port:
unsigned char open_port(HANDLE *hSerial, unsigned char port)
  DCB dcbSerialParams = {0};
  COMMTIMEOUTS timeouts={0};
  char com_port_name[30];
  sprintf(com_port_name, "\\\\.\\COM%d", port);
  *hSerial = CreateFile(com_port_name,
       GENERIC_READ | GENERIC_WRITE,
       0,
       NULL,
       OPEN_EXISTING,
       FILE_ATTRIBUTE_NORMAL,
       NULL);
  if(*hSerial==INVALID_HANDLE_VALUE)
      if(GetLastError()==ERROR_FILE_NOT_FOUND)
printf("Port %s not found\n", com_port_name);
      else
printf("Error opening port\n");
      return 0;
  dcbSerialParams.DCBlength=sizeof(dcbSerialParams);
  if (!GetCommState(*hSerial, &dcbSerialParams))
    printf("Unable to get state\n");
  printf("Rate %ld\n",dcbSerialParams.BaudRate);
  dcbSerialParams.BaudRate=CBR_115200;
  dcbSerialParams.ByteSize=8;
  dcbSerialParams.StopBits=ONESTOPBIT;
  dcbSerialParams.Parity=NOPARITY;
  if(!SetCommState(*hSerial, &dcbSerialParams))
    printf("Unable to set state\n");
  timeouts.ReadIntervalTimeout=2;
  timeouts.ReadTotalTimeoutConstant=10;
  timeouts.ReadTotalTimeoutMultiplier=0;
  timeouts.WriteTotalTimeoutConstant=0;
  timeouts.WriteTotalTimeoutMultiplier=0;
  if(!SetCommTimeouts(*hSerial, &timeouts))
  return 1;
Here is how I read it:
double read_angle(HANDLE hSerial, DWORD *PZ)
   int i=0;
   double angle=-100.0, angle_new;
   DWORD dwBytesRead = 0, PZ_new;
   char szBuff[200];
   *PZ=0;
   if(!ReadFile(hSerial, szBuff, 200, &dwBytesRead, NULL))
       printf("Unable to read\n");
       return -100;
   while(i<dwBytesRead)
       printf("%c", szBuff[i]);
       if(szBuff[i]=='Z' && ((i+5)< dwBytesRead) && (szBuff[i+1]==':'))
   if(sscanf(&szBuff[i+2],"%ld",&PZ_new)==1)
       *PZ=PZ_new;
       if(szBuff[i]=='e' && ((i+5)< dwBytesRead))
   if(sscanf(&szBuff[i+3],"%lf",&angle_new)==1)
       angle=angle_new;
       i++;
   return angle;
Offline KE5FX
    • KE5FX.COM
Maybe they turn on the DTR and/or DSR lines?  Some devices want that, some don't.
Offline Macman
You need to set the flow control fields in the DCB and possibly also the RTS and CTS states if you are not using hardware flow control.
Thanks!
This was all I needed to add:
  if(EscapeCommFunction(*hSerial, SETDTR)==0)
    printf("Error Setting DTR\n");
Online abyrvalg
This fix doesn´t cover all cases. You are still depending on some previously set parameters (i.e. enabled Xon/Xoff flow control can produce weird effects after receiving some specific bytes). For a full coverage don't do GetCommState() but fill entire DCB structure, setting all unused modes to FALSE/DISABLED:
https://msdn.microsoft.com/es-es/library/windows/desktop/aa363214(v=vs.85).aspx
