yea i want a small device I can tap into a serial data stream to show me whats going on in a larger device
i am disappointed that a 16x40 display is 250 euro, since the 4x40 are like 10 dollars each.
I was hoping to keep it simple with what I know so this project is not a big deal, I had EMI issues with TFT displays before making something simple turn into a total bastard (their module would not work with a cable extension), whereas my experience with the x40 displays has been stellar with crappy design.
I barely want to do this project and if I need to figure out decoupling after i extend something by 2 inches its a problem. I am used to stuff being touchy like that to pass a compliance, but for it to just stop working totally is new, which is what I had with a TFT shield a while back. This thing reset looped after it was extended vertically by 2 inches, meaning dual CPU system, since the TFT needed to have a MCU right under it to work. And it was just extended on headers that move right up, not like a cable. I am sure it was not a continuity error because I got SLIGHTLY less nasty reset loop when I did some stuff with braid and ground points........
. Anyway total bullshit for the ease of use you are supposed to get with shields etc, it would have been easier to design an entire PCB then figure out that retarded signal integrity problem. About as useful as a deck of cards because it will never translate to a realistic system! rapid prototyping my balls, you get a design that does not migrate at all to the real world with a TFT shield from my experience. And its not like you can copy the shield because the parts used are not economical most likely and you need to change code afterwards so you might as well not use it.
Those chinese LCD modules are happy to work with minimum libraries and cheapest poorly crimped long thin gauge extension header with connectors that loosely fit into other connectors on a ghetto bread board. Extremely robust display solution, I am lucky to have started working on that component with my first designs. I can certainly make a TFT work, but its just not worth the frustration,
the 40lb device seems like a better bet. Can it do SPI or only RS232?
and, there is no standard chinese type 16x40 or similar display available for modest cost?
