Hello,
I would like change the fans of a Poweredge R810 with quieter ones. The problem is that the current fans use what appears to be a proprietary header. I want to preserve these fans so I do not want to cut and splice the headers from them to the new fans. I checked on DigiKey with no luck.
Here are some pictures:
In case the exact thing cannot be bought off the shelf, I would be happy with a header that matches the "plug" portion; I do not strictly need the flat "base" portion.
Here are the dimensions of the "plug" part:
5.8mm X 7.2mm
2.5mm - distance between the pins
10mm - the "height" of the "plug"
Thanks again for your help!
