I'm repairing my Dad's 1959 Grundig cabinet radio. The fuse is still good but I can't figure out what type it is. It must be a slo-blo of some kind to allow the filaments to heat up I guess, but I've never seen a 5mm x 20mm 1 amp fuse built with two tension springs.
I usually see that kind of arrangement in higher current ratings.
Would a modern slo-blo fuse work as well? I'm asking because I recently found out there are no more electronics stores near me or my Dad's place that sell fuses anymore, so I have to use my limited stock of 5x20 fuses.
I can see the fast acting type just has a hair-thin filament, and the slo-blo variant has a blob of solder or something on the filament.
Are there different ratings of slo-blo, like even slower for tubes?
