Author Topic: Opinion needed on lm2956 based portable power supply  (Read 4814 times)
Offline AsimTopic starter
« on: July 15, 2014, 06:40:05 am »
Hi guys,
 i am planning on making a portable power supply ( I move a lot) and I decided not to bother building one ????, so I want to use this one http://m.ebay.com/itm/400561586157?nav=SEARCH
As the power supply. I will have 18650 batteries as the input ( they will be connected to a charging module so i can charge them without taking them off)
Here is a review of the product
My input will be 14.8v , it will not be used for high currents ( not more than 1.5A)
Do you think there is/ are reason/s for me not to go ahead ?
Offline Zepnat
Re: Opinion needed on lm2956 based portable power supply
« Reply #1 on: July 15, 2014, 07:20:58 am »
Sounds great, I would love to a have portable power supply so I've been using a Heath Robinson lash up with a lm2596 and two lithium 18v cordless drill batteries in series and it works great. If you used protected cells there wouldn't be any worries about over discharging and subsequently killing the battery. Please don't use any of those garbage 18650 on ebay with ***fire on the label but you probably know that already.
« Reply #2 on: July 15, 2014, 07:31:47 am »
For proteceting the batteries from over discharge or charge. I will use this http://m.ebay.com/itm/261191600278?nav=SEARCH
( never tried it before or seen anyone using it) I will test it and hopefully it is good enough.
Btw, what is wrong with ultrafire batteries ? I have used them before
Online tom66
« Reply #3 on: July 15, 2014, 09:27:27 am »
They usually won't meet anywhere near the printed rating.
eBay sellers are selling 5000mAh and even 6000mAh 18650s. Completely nonsense. Panasonic (an actual battery manufacturer) recently announced they had achieved 3900mAh in an 18650 with new silicon electrode design. So it's laughable for an ultrafire to even come close. Most of them are only in the 500mAh range, sometimes even less.
Offline Zepnat
« Reply #4 on: July 15, 2014, 10:12:36 am »
Just watched that review video and  I must say I'm very temped to get one of those power supply boards..
A few years ago my first torch batteries were ultra fire but they were just too inconsistent with missing safety features and wildly varying capacities any name brands are much better.
http://budgetlightforum.com/node/27603 why do they go to so much trouble to fake something that's only worth a couple of dollars  :-//
How about posting some photos when you get it up and running?  :-/O
« Reply #5 on: July 15, 2014, 01:45:27 pm »
I will put some photos when I finish it( waiting for the components atm )
Offline mij59
« Reply #6 on: July 15, 2014, 03:11:55 pm »
What output voltage range do you have in mind ?
Offline Alex Eisenhut
  • Place text here.
« Reply #7 on: July 15, 2014, 03:14:19 pm »
Yeah I've had mixed results with batteries on eBay, perhaps the rating refers to total lifetime capacity as you can only charge them 10 times...
Offline Zepnat
« Reply #8 on: July 15, 2014, 08:24:14 pm »
Ha Ha very good  :-DD
