I need to screw (I guess) my battery holder (4xAAA) to my PCB.
The holder already has two countersunk holes of diameter 3.2mm.
What is the normal was to do it? Is the best solution to have a hole put in the PCB then use a self-tapper or use some kind of tiny bolt?
Either way, what make/model of screw/bolt should I use?
Thanks.
