OK finally getting something going , I know about series / parallel , but did not bother to look , most of the time I have been at coffee shop when I posting here , so not able to look & test .
So just now at home , and looking for indications of how theses are connected [ to keep storage handling easy , I have been using just one half of strip , there length ] , so now looking at the surface to see traces under white paint , and then start thinking that I may need to connect the 2nd half of strip to complete the circuit , hook up to variable power supply .
And the findings are the 1st noticeable light happens at about 42.2v with current set at min.
And brightness stops at 49.4v , current set at min.
Then max brightness at 59.9v , current at 200ma .
Then with voltage at 59.9 , they start to dim at 100ma .
Glad I chose to get a 0-60v , 0-2a power supply , some time ago , thinking may end up playing with tele-com gear - 48v .
