Yes. I was doing precision analog, also HV, in the 1970s, and back then you had to develop all kinds of weird techniques. So a job got solved with 10x more parts than would be the case today. A lot of stuff used hand-selected / matched components, especially references, and (for HV) feedback resistors, temperature ovens for references, etc. It was an interesting area because those who developed those skills were able to sell products which nobody else could make. And some of it has not got easier because so few people understand analog.
Today you just buy a 1ppm/C ref for a few quid, an op-amp for less, and you are mostly done.
Today's precision is amazing. I am building a product with an ADS1118. All of them have their internal Vref within about 0.01% - many times better than the spec. Even the 10 pence TL431 tends to be within 0.01% or so. Well, they are laser trimming, so why not laser trim to 0.01% even if the spec says 1%.
In this case, building a 1kV op-amp, just throw in some 4kV devices and you are done. Just don't blow yourself up - this stuff is fatal!
