Hello Mates,
me and my dad have a few cars that are "out of service" but we'd like to turn their engines on more often.
Its common to have to crank old engines a LOT for the fuel system to blead, specially diesels so the battery often dies, even with a charger in parallel.
Automotive lead acid batteries are a pain, they are expensive and gets destroyed if they go flat (deep cycle discharge).
I'd like to have a 14V high current power supply to crank the engines, I've thought of a few options and I'd like your suggestions:
#1 - Get a 250A DC stick weld, modify the output transformer to lower the voltage (or maybe just the feedback) and increase (or maybe not) the rectification, and use it in parallel with not so good battery, as capacitor
#2 - Use a few server power supplies in parallel. They often 12.5 V @ 50...60...70A output current, maybe 4 in parallel could work.
Any way, I'm looking for options
Greetings, renan
