Author Topic: Jellybean FPC connectors that are footprint compatible from 2+ brands.  (Read 148 times)
Offline PsiTopic starter
I'm adding a FPC connector to a product and I'd like to use one that is available from more than 1 manufacturer  (eg footprint compatible).
But checking them 1 at a time and looking for others that are the same is super time consuming.
Any ideas for FPC connector series names that are considered Jellybean?
Probably 1mm pitch
Probably be 8 or 14pos depending if I have room and want to double up conductors.
Doesn't realty matter if it's top or bottom contacts.
Needs to have a locking latch.
