Now that I have more things working it turns out that using the 1013D code for the sampling is not as straight forward as thought.
While working well on the 1013D for determining the signals frequency it fails at it on the 1014D, even though the signal on the screen looks ok.
Checking the FPGA command trace on the emulator shows that it always uses the same value for writing to command 0x0D, which in the 1013D is used to set the sample rate. The command 0x0E values seem to be the same for as far as I checked, so it might be that this is used in the FPGA to also select the sample rate, and not just some setting for the time per division, like in the 1013D.
Looking at the trace data did show the usage of the new command 0x29. When written 0 it only reads from one ADC per channel, and when written 1 it reads both ADC's for each channel. The latter is only done for the 10ns/div setting.
So more experimenting is needed to get a properly working scope.
Edit: I added command 0x29 to the code and now it shows some stable frequency reading, only way off what it should be. 100KHz reads as 19.2Hz.
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
That does match with the trace shown on the screen. 10ms/div and ~5.2 divisions for a period.
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
Edit 2: Ahum, that is due to aliasing. When the time per division is set to 2us/div it shows the correct frequency, but the signal on the screen has a lot of artifacts, not seen on the 1013D.
Edit 3: It has been to long since the reversal of the 1013D.
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
I thought I had the special IC fully implemented in the 1013D emulator I wrote back then and used it with modifications for the user interface to make the emulator for the 1014D. But it turns out I did not do that and therefore the command 0x0D value it outputs to the FPGA trace file is not correct. Can't remember how I found the values for it when working on the 1013D, but need to do it again for the 1014D.
One thing I did notice, when looking through the code in Ghidra, is that the handling of the roll mode (long time base settings) is done differently. Just like when I did the 1013D, I'm going to skip that part.
Another thing is that the values used for command 0x0E are different except for the last one used for sampling at 200Msa/s. But these are easily copied from the code in Ghidra.
