Everything is overclocked, so does not work reliably in some cases. Analog front-end is a joke, and has strange offsets and gain issues that. I make an attempt to calibrate them out in the firmware, but the result is not perfect.
The stock firmware is just crap. Typical for this kind of product - UI that is unintuitive and frustrating to use. My firmware makes an attempt at a better UI, and generally it is functional, but would need more work.
If you need a unit that just works, then I personally would pass on this one. But if you are ok with it being a project, then it is more of less fine.
