I know carbon composition resistors have bad VCR (Voltage Coefficient of Resistance), but modern ones have far too good VCR specs to be any fun anymore
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
I know I could use some simple BJT or FET as a variable resistor to achieve the same effect.
but what options do I have with just resistor types (and yes I know it depends a lot more on the size and value of the resistor most often)
I was thinking maybe LDRs would have bad VCR since they're... terrible in everything else, but I couldn't find any datasheet which listed a spec for VCR.
and also, I see positive and negative values used for VCR, sometimes having negative ppm/V and positive %/V specs in the same sentence but in the next sentence it's negative %/V...
so, does a carbon comp resistor have positive resistance change per voltage (+ %/V?, + ppm/V?) and would increase in resistance the more voltage is applied to it, or the other way around?
