Firstly, Thank you to all! This information is very helpful.
If my responses come across as being argumentative, this is not my intention, i'm just trying to fully understand...
I mentioned it because many soldering irons and industrial temperature controllers work in exactly this way. A TRIAC is the power element and it is modulated using PWM over whole numbers of power cycles with triggering only at zero crossings.
I do not see any advantages to using an IGBT and many disadvantages.
Indeed. The details given in the OP are very vague, but if we presume this is a standard resistive water heater that will run from a regular AC mains supply, then it has a slow response time and significant thermal inertia. As a result, controlling power in whole (half) cycles would seem to be very direct and efficient.
Wouldn't this be an ideal application for a zero crossing initiated TRIAC? The controller should modulate it for a whole number of cycles to produce the correct output level which presents an interesting challenge.
TRIACs were the first chose in designing this circuit. Unfortunately I forgot to mention in the first post that the MC driving this circuit is running "parallel" processes and can't handle dealing with measuring zero crossing. At any given point, the MC measuring 2 pressure sensors, 2 RTDs and driving 2valves and 2 of these heating elements. It's convenient to set the MC to output a PWM and then go do other tasks in "parallel'.
Also, What package besides TO220 do TRIACs come in? The beauty of my IGBTs is they they except lug terminals and mount directly on a heat sink. Are there equivalent TRIACs?
I suggest that you build a scale model of your circuit using a transformer rated 36vac and 2A and use a 33 Ohm load. Use 3x 100 Ohm in parallel.
I have a set up at lab that allows me to work with conditions similar to what you suggested and that indeed is my intention. Don't have a death wish...
Thank you very much for the Spice sim too! b
What level of school is this?
Undergraduate first semester Senior Design.
If this is for school, then the whole idea of the project is to fail. Great ideas fall apart fairly quickly when you try to implement them. So why are you using an IGBT, just because you have them? That will waste about 20W, not really a design. I get all my hot water at camp by modulating the elements so the panel is kept at the power point voltage. Nothing gets hot. I hate wasting energy. Think of all the places you are wasting heat/energy.
Very True! School projects are some what met to make you fail in a safe environment, that way you don't fail as much failing on the job.
IGBTs were chosen for the price, current and voltage ratings, and most importantly, do not need to be mounted on a pcb. 240V PCB with a TO-220 package scares me.
Also, can not agree more with the idea of wasting energy, but school is an exception
So my new question to you guys:
1. Would punting the heater in the AC side of the bridge be better? Let the grid absorb some of transients?
2. If say this design fails, can you please give some suggestions for a power supply that only needs a PWM for the MC to run.
Thanks Again!
