Author Topic: Resistor combination calculator  (Read 19926 times)
Offline EliminateurTopic starter
  • Country: ar
  • Electronic's Technician
« on: January 07, 2011, 09:52:15 pm »
Here's the short version:
I have a large bunch of assorted resistors WITH assorted tolerance values and i'm currently building a circuit and i require some weird nonstandard values(and standard as well).
Before going to the electronics store, i might as well check wheter i have or can combine any of my resistors for this purpose.
So my plan/what i need is:
1) Enter all the resistors i have, ammounts, tolerance(AND maybe power) into a spreadsheet(google docs, maybe excel, whatever works best)
2) Put my desired resulting value and tolerance and with some mathematic mumbo-jumbo the program/spreadsheet returns the combination(parallel/series/combination para-series) that will result into my value(taking tolerance into account(in the simplest way only take into account <X tolerance resistors, in more complex scenario, take all tolerances into consideration and see if results falls into resulting tolerance).
could also put another option to chose a limit on how many resistors you desire in the result.
i've been googling for something like this but the closest i've found is a website that allows you to enter a certain number of resistors and your desired value, but it's far limited as the data sample is too small to be of use.
¿any ideas on the math i should do(i can't remember squat about advanced math/calc/stats from uni, always hated it hehe), the workflow or program to use?(one of my ideas is to make a program for this into my Casio 9800G calculator, but that would leave me with the data stranded there, and my other more advanced calc i haven't got the slightest clue how to program it).
i don't know what would be the optimal path for the program(even if the loops aren't the best) to determine a value or return an error if it's impossible(and returning the resulting value and what resistor you need).
what would be best?, try summatory of values <desired and record closest matches(and what would be "closest"?), then try parallel(but with how many parallels?, 2, 3, 4, 10?), and then try combination?(and how do you chose how to cobine them?
meh, i'm so lost in this...
cheers!
Offline Bored@Work
Re: Resistor combination calculator
« Reply #1 on: January 07, 2011, 09:55:16 pm »
Here is your calculator
http://en.wikipedia.org/wiki/File:Nomogramparallelresistance.svg
From those days when men were still men, and engineers still engineers.
  • Country: ar
« Reply #2 on: January 08, 2011, 01:05:30 am »
i don't quite follow how that could help me as it's a graphical aid for calculating parallel resistance whilst i need a loop approach for method decision and minimization of difference/components.
thanks anyway
Offline jahonen
« Reply #3 on: January 08, 2011, 08:34:43 am »
I have used my Resistor optimizer for some time now. It has been quite adequate for practical problems, despite the "brute force" approach.
Regards,
Janne
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #4 on: January 08, 2011, 01:24:54 pm »
Nice!  Thank you.
For my need I calculate non-precision resistances usually by determining current I need to find the wattage value to use, then just use a combo of 100kohm values I stock to zero in on the resistance I need.  This is apart from the capacitance and inductance such combos cause in precision requirements.
A single value like 100k in parallel/series combos can give a host of combinations you can use to zero in on the value you really need; its easier than stocking a lot of different types of values for resistors.
Successive 100K in parallel will yield:
50, 33, 25, 20, 17, 14.3, 12.5 etc., then mix series and parallel values until the value you need is won.
Regards,
Janne
« Last Edit: January 08, 2011, 01:48:55 pm by saturation »
Best Wishes,
 Saturation
Offline johnmx
  • Country: pt
Best regards,
johnmx
Offline Bored@Work
« Reply #6 on: January 08, 2011, 05:59:55 pm »
You failed to understand how it can be used.
Online blackdog
  • Please stop pushing bullshit...
« Reply #7 on: January 08, 2011, 07:15:16 pm »
Hi Eliminateur :-)
Try this little program, download is from my server => www.bramcam.nl/Rescalc.exe
It wil help you with parrralel resistors.
Maybe this Spreadsheet is also helpful => www.bramcam.nl/Electric-Excel.xls
Kind regarts,
Bram
Necessity is not an established fact, but an interpretation.
  • Country: ar
« Reply #8 on: January 10, 2011, 06:40:42 pm »
oops, sorry for the delay, i was convinced i had setup the notify on reply but no... anyway, ive been looking at your posts and letme go by order:
@jahonen: excellent soft it's almost what i had in mind, but i don't quite inderstand what's "upper and lower" resistors and it seems oriented for voltage divider, i don't quite follow it (for example, to use series alone, do i put the same value in to/from, then check series, ignore division factor, check available values and choose how many resistors in series to consider?, am i wrong?).
@saturation: i already have this bunch of precision/non precision resistors and want to see what if i could accomplish the values i need with them, if i need to go get new resistors, it defeats the initial purpose.
@johnmx: umfortunately not what i was looking for, that rescad soft you input a value and it tells you what closest Exx values you need to accomplish it and with what error, seeing as to reach a value i can use thousands of combinations with the resistors i have at hand it's not of much use.
@boredatwork: explain it.
@blackdog: similar to rescad it's for the reverse path of what i need(you need an X value and the program tells you the Exx combinations closest for it, then you go buy them/check those specific values), but again, i add a layer of complexity in that the soft should check not a Exx range, but a finite list of existing resistors to make the combinations(and it also uses a 2-resistor limit). All in all it's almost there but on the reverse path ;).
What it is is extremely useful to find the combination(or direct value) for a resistor you just calculated in your circuit based on Exx values.
I like how it presents the other results below, so far i think it's the closest to what i need
Nice spreadsheet, i'll save it for future use(doesn't has what i need for this problem as well)
thanks everybody, now to see if the circuit works... :D
Online blackdog
« Reply #9 on: January 10, 2011, 08:34:53 pm »
Maybe this program can help you a little...
www.bramcam.nl/Res-Optimizer.zip
Unzip en run the ResOpt.exe, Make a copy of the E96.res name it "Myres.ser" edit this file with "Notepad", put your values in it and save.
Now your happy ;-)
It uses a text file for the resistor values, you can put your resistors in it :-)
Kind regarts,
Bram
Offline jahonen
« Reply #10 on: January 10, 2011, 09:14:33 pm »
Yes, the resistor optimizer was originally for optimizing the dividers, but there is a parallel resistor optimizer tab available which lets you to optimize parallel combinations of resistors to achieve specified target resistance.
I'm working on a new version, which has some enhancements, like series optimizing for target resistance and taking source and load resistances into consideration when optimizing dividers (I actually needed that feature).
Regards,
Janne
  • Country: ar
« Reply #11 on: January 11, 2011, 04:59:34 pm »
@jahonen: looking forward to new version, because atm it can only calculate parallel combinations, does not take serial into account.
a combination of rescalc and resitor optimizer would be awesome(bad thing about rescalc is that it only takes 2 resistors into account for serial resultants.
@blackdog: yeah it's the same one that was posted before, i'll load my values into excel then export it to txt and see what happens :S
can you believe that my 2 largest local electro-shops almost do not stock 1% resistors.... :'(
Offline jahonen
« Reply #12 on: January 11, 2011, 07:27:46 pm »
FYI, the new 0.45 version should be available now on the URL I posted before. Check it out! :)
Note that although optimization using nominal value might get the value you are after, it does not improve tolerances. So resultant resistor still has bad tolerance. And of course, LC-parasitics will be multiplied compared to single resistor, sometimes that matters.
Regards,
Janne
  • Country: ar
« Reply #13 on: January 11, 2011, 07:56:38 pm »
downloading....
i'm not expecting better tolerance, it's just that i simply can't get the values i need here(we're in the stone age of electronics, for example, you simply cannot get any smd components at all).
luckily my design is pure constant DC so i don't care about LC-values going haywire
  • Country: ar
« Reply #14 on: January 17, 2011, 05:22:31 pm »
absolutely fantastic Janne, you deserve a box of cookies!
Process was: inputting values in K in excel(along with quantity), exporting as CSV, replacing ";" and . to ,
fiddling with number of resistors to get optimal results and deleting(or not) from source file if i depleted said value...
not the most direct method but pretty straightforward and works like a charm!
turns out i could build all the resistors i needed from the assorted box!, this just saved me a ton of cash and grief(large distributors that carry 1% resistors would only ship for orders >25$, and i needed at most 1~2$ worth of resistors...., PLUS the shipping charge, another 10$~)
now ontowards the build! :P
Offline brian1taylor
Re: Resistor Combination Chart Calculator
« Reply #15 on: May 18, 2014, 01:52:10 am »
Hi all,
For your information attached is a resistor combination chart I've used before. It is from Electronic Australia 1975 and contains the original Fortran program which I've transposed to C#. I like it because it shows all the best combinations in a couple of pages. A high resolution of the original is available at:
http://www.logostechnology.com/ResistorCombinationChart.pdf
Brian
Offline mariush
« Reply #16 on: May 18, 2014, 07:07:37 am »
There is another thread about a resistor calculator on this forum. Not to say that your contribution isn't appreciated, just point out that there are already some alternatives.
There's also the online solution of using Wolfram Alpha for example, which was mentioned in one of those other threads: http://www.wolframalpha.com/input/?i=1234+Ohm  Scroll down and you will see the engine giving you suggestions of series/parallel resistors to get to that value.
Offline LukeW
« Reply #17 on: May 18, 2014, 11:07:16 am »
http://jansson.us/resistors.html
I like this site. Find a match to the closest E-series preferred value with whichever series you want, using either a single resistor or series/parallel combo.
You can also do voltage divider calculations (eg. for opamp or regulator feedback) choosing E-series values combined to match your desired ratio most accurately.
Offline acolomitchi
« Reply #18 on: July 21, 2016, 05:01:55 am »
I'll just let this here:
http://caffeineowl.com/electronics/calcs/rescomb/index.html
JavaScript based (uses your browser), series/parallel or both, allows custom subsets of E12/E24, goes up to 4 resistor networks with a full E12 in input, 3 for E24, up to 6 resistor combinations for limited number of the input set.
Cheers
Offline Kirr
  • Country: jp
« Reply #19 on: July 21, 2016, 06:09:26 am »
Here is one another calculator: Resistor Network Finder
Supports configurable stock (series, bases, range, gaps, extras), configurable target error, finds networks of up to 6 resistors including bridges, supports a list of target resistances. Runs on server side, so it's quite fast and won't freeze the browser (the downside is that in the unlikely event of too many requests the server might slow down). It's currently limited to 20 million networks per search.
It also shows the schematic of each found network. :)
Offline acolomitchi
« Reply #20 on: July 21, 2016, 08:59:39 am »
Did the other one freeze yours? (is meant to work one a separate thread, WebWorkers and stuff).
If it did, what browser have you used?
Offline Kirr
  • Country: jp
« Reply #21 on: July 21, 2016, 09:12:18 am »
No, but some other JavaScript-based one did (forgot now which one). By the way, congrats on a very nice tool! The dynamically updating list of matches looks great. I will soon add it to my list of calculators.  :-+ (By any chance, do you have any interest in making a network solver too?)
Offline acolomitchi
« Reply #22 on: July 21, 2016, 10:25:18 am »
Thanks.
BTW, get on github, download it as a zip, unpack in a directory at you liking, start index.html and you get it no matter if the caffeineowl server goes down.
Well, almost... some browsers are more finicky.
You mean resolving currents in a resistor network (Kirchhoff and the like)?
If not, what do you mean?
Offline Kirr
  • Country: jp
« Reply #23 on: July 21, 2016, 04:00:58 pm »
Thanks, and nice of you to share your code. I should probably clean up and share my code too.
I mean finding the equivalent resistance between any two nodes of an arbitrarily complex resistor network. It's a kind of opposite problem compared to finding the replacement network for a missing resistor value. When finding the network, you try to find the best network for specified value. When solving, you are given a network, and now you are trying to find the equivalent resistance. This is a fascinating problem, especially if the network is large.
Offline mathsquid
  • I like math.
« Reply #24 on: July 22, 2016, 12:24:24 am »
I mean finding the equivalent resistance between any two nodes of an arbitrarily complex resistor network. It's a kind of opposite problem compared to finding the replacement network for a missing resistor value. ... This is a fascinating problem, especially if the network is large.
Yes it is. There is a known solution for computing the resistance between any two points in a given network of resistors, but you need something like MATLAB or SageMath to compute it, because it involves taking the Moore-Penrose pseudoinverse of a noninvertible matrix. If you google "resistance distance", the formula is on the wikipedia page, but it's not the best explanation. The paper by Klein and Randic (http://link.springer.com/article/10.1007/BF01164627) has a good explanation, but unfortunately there doesn't seem to be a copy of it on the web. PM me if you want a copy.
The following users thanked this post: Kirr, acolomitchi
