Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Parallel LiPo Battery System
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Parallel LiPo Battery System (Read 105 times)
Kuusou
Contributor
Country:
on:
Yesterday
at 01:52:22 am »
I'm seeking feedback on the design of a parallel lithium polymer battery system shown in the attached schematic. The primary goal is to safely combine two individual battery packs to increase system capacity while preventing any negative side effects, such as mutual influence between cells.
Design Details:
Battery Management System (BMS): BRCL3130ME
Datasheet:
https://wmsc.lcsc.com/wmsc/upload/file/pdf/v2/lcsc/1811141355_Foshan-Blue-Rocket-Elec-BRCL3130ME_C328560.pdf
Charging IC: PJ4054B
Datasheet:
https://wmsc.lcsc.com/wmsc/upload/file/pdf/v2/lcsc/2110272230_PJSEMI-PJ4054B_C2911335.pdf
Low Voltage Cutoff: APX803S-31SA-7
Datasheet:
https://wmsc.lcsc.com/wmsc/upload/file/pdf/v2/lcsc/1811141622_Diodes-Incorporated-APX803S-31SA-7_C129757.pdf
P-Channel MOSFET: AS3423B
Datasheet:
https://wmsc.lcsc.com/wmsc/upload/file/pdf/v2/lcsc/1912111437_FMS-Formosa-Microsemi-AS3423B_C341542.pdf
Questions:
Do I need to add Schottky Diodes between the APX803S-31SA-7 and each LiPo cell before they are connected in parallel to prevent mutual influence?
Is the current layout needlessly complex? Can the individual battery packs (same manufacturer and rating) be combined in parallel safely without all these extra components? For example, could they be connected together in parallel with each cell only having it's own BMS and use one charging IC? Are my concerns with the batteries influencing each other and equalizing valid?
Any insights or recommendations for improving this design would be greatly appreciated.
Last Edit:
Today
at 10:22:45 am by Kuusou
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
