well you work on your VA rating, the one you chose has a rating of 48VA, so the 30V secondary is likely when your pulling 1.6A on the output, and it will float a little higher at lower loads, (good thing to know if your components are only 36V) as transformer ratings are usually what voltage its at when your pulling the rated wattage / VA,
so if your only looking for 20V, you can get away with a 24V, 28VA rated transformer, and if you need higher current you chase a higher VA transformer, (generally get one rated atleast 2-3V above your ideal voltage for your bridge rectifier)
