That's a nice mod alx2009, I like the back of the board too with the copper clad island style.
I have a K197 that I just updated the buzzer circuit I made for it, and also had too add a shim under the LCD, to keep enough pressure on it to make proper contact.
I also tried adding a front light, just something I could tape to the outside of the front panel, under the LCD. I put some white LEDs in a piece of outer insulation, from CAT5 type cable. I thought maybe shinning a little line of light from it onto the LCD could work. It looks ok if it's a few inches from the glass, but up close, all I see it the reflection of the LED's.
The tube/jacket of CAT5 insulation is white, and even with it turned around so the light passes fully through the insulation, not the slit I cut, it's still not diffused enough. So it still looks like 4 LED's are inside the glass, and you can't read anything.
Now I really wish the screen was bigger too, but for now, I have a VFD unit, from a DVD player type thing.
It has 6x number/letter blocks. They are like 7-segment blocks, except with 6 extra lines, 3-top, 3-bottom.
Then there's a about another 12 special characters like "DVD", "Total", "Title", even pictures like play/pause and a movie camera. So they could be used too, I'd just need a translation guide on the DMM.
The VFD is on PCB with some function buttons, a ceramic resonator, and a big IC/driver for the VFD, if not the whole DVD player or whatever it was. The whole PCB is a very similar size to the Keithley LCD one. There's also an IR receiver PCB is still connected to this main PCB too. The IC is a CH72FG-4U54, can't find anything on it yet, I think it's by ST, if I remember their logo. Looks like the year 2003.
IDK how much power it takes to drive something like this, I think it uses some higher voltages though. But I could add some other little transformer inside the case if needed.
I don't just want to copy/paste someone else's program for driving some new display, I think it's a small enough project that I might be-able to do it on my own, as a learning project with Arduino or some other MCU as easy to use. Or at least a lot of it
IDK for sure this VFD works fully, I briefly tested it years ago with power, it does something. Aside from being a little smaller digit size, if this thing is bright enough, it could be great.
But IDK tho, the VFD itself, is not as long as the original LCD, but slightly taller. The VFD could probably fit, but the PCB that the VFD /chip are on, might be a problem, it's about 1cm taller than the Keithley 1, and tons of traces from the IC go right to the edge.
Oh there might be a problem with the decimals tho, on the VFD there's
"0- 0: 0- 0: 0 0" , but there is "TRK" and "M R" right above the last 2 blocks that don;t have any symbol in between.
It's not ideal, but I would like to see it working, if possible. I just saved the the VFD for something to hack at. Later I can still get an OLED or other display, to try with the Keithley too.
