Thanks for the links James, there's a guy on YouTube that used similar cylinders with brass fittings and nylon air line, compression fittings I think. The relay link I will try and find UK sales for it, thanks for that.
I'm only going to do this once...
A bucket list thing if I'm around long enough. Some years ago I got interested in airbrushing from a library book lol, before computers where around. Some years later I pulled a fridge compressor and fired it up, with a plan to build a unit for airbrushing, it never happened.
This time I was hoping to get my Son interested, he's into the Marvel stuff and super hero's etc, thought he might want to try airbrushing some stuff. As I'm only going to get one chance at this, and after looking across the web, I've kind of got taken with 3 phase. I know it cost a fare wack more, but I wanted a unit my Son could still use in years to come. So at the moment VFD's look the best option for this, the only slight off putting thing is the winning you get from the frequency carrier, I think it's that. But hoping the better quality ones are not so noisy. 3 phase fridge compressor, VFD control, usual pressure switch and regulator for output air. Coupled up with a 25 or 50 litre air receiver. I did briefly look at 100 litre air receiver and quickly worked out that's just daft. The VFD would just offer better control of the compressor. 3 phase as these look like much higher volume of air output. The idea being some quite times between compressor filling the receiver, although there fairly quite anyway. As it's something I want to last I might as well throw a few bob at it.
