Hey guys,
I know the chances are slim but I figured I'd give it a shot.
Does anyone know if it's possible to source this connector and it's mate?
The connector is from a 2014 Honda Odyssey minivan's power drivers seat. It's on the seat adjustment switch module PCB. This connector then goes to the cable assembly that connects to the power and each of the 4 adjustment motors.
There are no markings at all on the connector.
The switch module part number is 81650-S3V-A01ZH
I think the cable assembly it mates with has the part number 81606-TK8-A22
It's really hard to tell from the spare parts diagram what things are.
http://estore.honda.com/honda/parts/view-honda-parts-catalog-detail.asp?m=2014-odyssey-5-ex-6at&sn=&b=B++4010&dl=#Anyways, I took a bunch of measurements and did this drawing in the hopes someone knows of a source or something similar.
It looks like Molex has some blade connectors like this but the pitch is not right.
It appears this same power seat switch module has been used for a number of years. I want to avoid the pick-a-part route if I can, but I know that's an option.
Lets see what you come up with. Thanks ahead of time!
::Edit::
I left of a dimension. The whole thing is 1.11 inches long.
