Hello everyone.
I'm working on a DC Voltage Reference/Calibrator project that would be comparable to Data Precision 8200 (hopefully better) in terms of specification i.e. about 0.01% accuracy (preferably better) with 6 digits resolution. The unit will be using a much more modern approach and components of course. I will receive my evaluation board for the AD5791 this week. That should allow me to experiment and prototype the DAC/Reference part.
I would like the unit to have a 100mV, 10V, 100V and 1kV or 1.2kV ranges. Since the DAC obviously won't output more then 2.5 to 10 volts (depending on vref), it will need some accurate amplification. This is not a big deal up to about 40V or so as there are many good precision op amps available. For the 100V range, I found this op amp:
https://www.analog.com/media/en/technical-documentation/data-sheets/adhv4702-1.pdfThis should be fine for 100V. An application note in the datasheet suggests a voltage range extension (basically bootstrapping) using an n and p MOSFETs on the positive and negative power rails respectively but it can only double the range. 200V is nowhere near 1kV. I'm also a bit concerned about stability since this is a rather fast amplifier for a DC application. It doesn't look like there is much choice anyway.
There is a 1kV op amp made by a company called Apex Microtechnology but it is very expansive (over 1k CAD). I guess I could go discrete and make an amplifier stage using an LTP feeding a cascode with negative feedback for linearity much like the VAS stage of classic audio amplifiers. This is what I'm considering at the moment.
I'm interested in any suggestion for the 1kV amplification (as well as the rest if you like). What would be a good strategy to get to 1kV while maintaining the precision and low noise.
Some complementary information:
- The device could be used to calibrate instruments that have a low enough precision but it would be used mostly as a precision voltage source.
- The device will be a benchtop unit with its internal power supply (one of the challenge because of high voltage).
- The voltage source doesn't have to be able to source much current as it will mostly be used with high impedance circuits. Maybe 10 or 20 ma max at 1Kv.
- I may eventually add a current source that could go to 100mA or 200mA, not sure though.
The complete and definitive specification is not yet determine as a lot will depend on what I can do with available components but accuracy is the main goal.
