One rated for 380VAC (or 530VDC / peak), of course.
Shouldn't have to be very big, it's not absorbing lightning strikes.
Size, voltage and form factor (wire leads, screw terminals, terminal blocks, etc.) are the only differentiating characteristics of MOVs, as far as I know. (There is a "sharpness" parameter, but I don't think it's usually very well if at all specified, controlled or selectable.)
Also very common to use an R+C snubber, usually 0.1uF + 100 ohms or something like that. These are available pre-packaged for panel wiring purposes.
