Author Topic: What is this adaptor Dave J. is using here?  (Read 440 times)
Offline CicadaTopic starter
« on: September 13, 2024, 09:27:44 am »
Hi
I would love to have such an Scope probe adaptor to BNC as shown in this video at time 14:38
I use tektronics probes.
Please not I am referring to the adaptor into which the scope probe, without it's cap, plugs into.
Perhaps there is an adaptor like this that plugs into male BNC plug.
Regards,
Cicada.
« Last Edit: September 13, 2024, 09:31:39 am by Cicada »
Offline Phil1977
Re: What is this adaptor Dave J. is using here?
« Reply #1 on: September 13, 2024, 09:51:03 am »
I just know the SMA-counterpart:
(Source: https://de.farnell.com/beehive-electronics/0309-0001/adapter-sma-jack-probe/dp/2786216 )
Unfortunately Farnell wants a quite professional amount of money for it. Does anyone know this for a more reasonable price?
Online squadchannel
  • Country: jp
  • deepl translate user
« Reply #2 on: September 13, 2024, 09:59:07 am »
I have it. it is an accessory for a Tek THS3000.
I think it is expensive.
Offline ttelectronic
« Reply #3 on: September 13, 2024, 10:01:20 am »
Probe to BNC adapter CT2708 (Cal Test)  Cal Test is a reasonably priced brand.
BNC ADAPTER 5MM NONTERMINATED
(5mm seems most common)
« Last Edit: September 13, 2024, 10:03:59 am by ttelectronic »
Offline sharow
« Reply #4 on: September 13, 2024, 10:51:27 am »
I saw this on Probe Master site. see 4987BA, 4952BA.
https://probemaster.com/oscilloscope-probes/4900-series/accessories/
But I think it's made for specific probes. Not universal.
Offline ajb
« Reply #5 on: September 13, 2024, 02:48:38 pm »
Yeah, there is some variety in the diameter of both the probe tip and the grounding sleeve, so the adapters are somewhat specific.  I have a set of the Cal Test CT2708, and they just barely work with some Rigol probes with a 4.7mm sleeve diameter if you squish the contact leaves a bit.  I don't know how consistent the dimensions of Tek probes are, so the OP may need to take some measurements first.  Whatever adapters Tek sells, there's a good chance they're available directly from whoever makes them, or under a different brand, at a better price.
