Hello everyone,
I tried to increase the output voltage of an old HP server power supply to 13.8V.
The model number is HSTNS-PL18 rated at 750W and I found two ways to do that
on the web.
The first involves bridging a resistor next to the voltage setting pot. That worked but
when I hook up my little ICOM IC-7300 transceiver and slowly increase HF power the
PS starts to make a strange noise at about 12 amps and higher. The higher the
current the higher the pitch and louder the noise. To me it sounds a bit like arcing
and this makes me quite nervous.
I thought that maybe the PSU picks up HF from the transmitter. So I got me an electronic
load and the result is exactly the same.
So maybe the PSU is defective. I got me another PL18, did the same mod but exactly the
same noise starts, although this time at 25 amps.
Removing the modification back to the original 12.3V I can draw 400W, the max my EL
can take, and both PSUs remain completely silent.
At this point I am looking for advise.
- where does this noise come from?
- will the PSU go up in flames if I ignore it? would my transceiver be at risk?
- are there better ways for modification or some of the other pots to change?
Thanks for reading.
73, Wilhelm
