brumbarchris and 3 Guests are viewing this topic.
Quote from: DanielRehak on August 27, 2024, 04:05:43 pmQuote from: mikeselectricstuff on August 27, 2024, 03:55:51 pmCould you stretch the grommet over a USB-C plug? Maybe with the plastic overmoulding stripped off?This can be done but you risk stretching the grommet so much it will no longer seal properly. You would need to find a grommet that fulfills following:1) maximum cable diameter that can fit inside grommet >= maximum USB connector width2) minimum cable diameter that can fit inside grommet <= USB cable diameterAnd there does not exist anything like that. Max specced dia when used in the gland isn't the same as what you can stretch it to when taken out of the gland.
Quote from: voltsandjolts on August 28, 2024, 04:10:05 pmhttps://www.lindy.co.uk/usb-c4/200m-fibre-optic-usb-3-0-extender-p9144...and othersThis looks interesting. It is definitely the smallest one i ever saw. But its pretty expensive and mainly it needs 5V 3A power supply which could be solved but would be high effort.
