Loading [MathJax]/extensions/Safe.js
Author Topic: DDS function generator  (Read 2842 times)
Offline jeffreyprinzieTopic starter
« on: January 30, 2013, 06:20:46 pm »
I am building a DDS function generator up to 6MHz with a DDS from analog devices.
As opamp I use the LT1226 having 1GHz gain bandwidth, enough with Lag lead compensation?
All amplitude and DC offset works, but the output buffer still needs to be done.
I was thinking about a Class AB push pull emitter follower. The output impedance is 1/gm , so with enough base current, 50ohm output impedance should be possible. The input impedance should not be depend a lot on the output capacitance, because that would change the output pole of the opamp leading to instability.
Should I use an open loop buffer or use feedback? opamp or not for feedback. I rather use no feedback for improved stability. The dominant pole must be on the output then, so capacitive load only moves it to the origin.
Amplitude max 5V
offset max +-5V
what solutions for the output do you propose?
Thanks!
Jeffrey
Offline Jay_Diddy_B
Re: DDS function generator
« Reply #1 on: January 31, 2013, 10:54:21 am »
Look at using the LT1210 for the amplifier / output stage.
With LT1210 you will not need an emitter follower output stage.
http://www.linear.com/product/LT1210
You should have a 50 Ohm resistor in series with the output of the amplifier, so that the source impedance of your function generator is 50 ohms.
Jay_Diddy_B
Offline bdivi
  • Country: bg
« Reply #2 on: January 31, 2013, 02:34:47 pm »
Another approach is AD811
I have built a function generator based on MAX038 that is good to 20MHz and the AD811 buffer happily drives 50 ohms with around 12ns rise/fall times.
cheers,
« Reply #3 on: January 31, 2013, 03:43:46 pm »
Thanks,
The LT1210 seems to do it well, i will orde one and see.
any sugestions are welcome.
I now made a class ab output stage which also works, but with the opamp it can be more linear.
kr
« Last Edit: January 31, 2013, 04:23:56 pm by jeffreyprinzie »
