Author Topic: Triac control system for soft start  (Read 1183 times)
Offline AnjaTopic starter
« on: November 21, 2022, 12:29:36 pm »
Hello,
I built a circuit in LTSpice in order to come up with a control circuit for the triac, which is designed to limit the current flowing to the receiver (which is the power supply), and without which there is an overvoltage that stops the voltage flow.
The plan is to design a triac control system that limits the current to 10 A but I don't know how to approach that.
The initial approach of applying a behavioral source of tension led to the analysis shown in the PDF document, which shows that this approach really has no effect.
What ideas do you have for the analysis circuit for LTSpice? I thought that the triac would control the zener diode, but I have too little experience to figure out how to work efficiently.
I am asking for help in inventing a system with a triac for soft start, so that a current of 10 A is constantly flowing to the receiver.
In the picture you can see a red rectangle and this is where you need to come up with a control system for a variable resistance load.
Best regards,
Anna
Offline DavidAlfa
Re: Triac control system for soft start
« Reply #1 on: November 21, 2022, 01:45:25 pm »
You can't limit the current with a triac, only works in off and on state, it's not a transistor, there's no way you can it use in linear mode!
It can only chop the AC wave, but once triggered it'll stay in conducting state, you can't switch it off (It's a latching device), the only way is to let the current drop enough so it releases itself, this is why it's only used in AC, the zero voltage crossing releases it.
Wave chopping operation (The red wave would be the voltage at the load):
Get yourself documented about how triacs work:
http://tahmidmc.blogspot.com/2013/07/ac-power-control-with-thyristor.html
« Last Edit: November 21, 2022, 01:54:59 pm by DavidAlfa »
Offline Brianf
« Reply #2 on: November 21, 2022, 03:43:05 pm »
What's your load? One usual technique for soft start is to have a series resistor which, after a time delay, is bypassed by a relay or triac.
Offline jonpaul
« Reply #3 on: November 22, 2022, 07:13:34 am »
Triac will cause issues on inductive or transformer load.
Simple soft start is a series NTC thermistor, perhaps $0.50
Why do you need a soft start?
What is the load type, V, VA/KVA?
Jon
Jean-Paul  the Internet Dinosaur
