Author Topic: RC delay after comparator or buffer?  (Read 263 times)
Offline okwTopic starter
  • Country: no
« on: June 09, 2024, 01:17:18 pm »
I use an opamp to determine if a sensor is above or below 2.5V. It has a lot more circuitry, I just trimmed it down for what's important. The sensor senses water level in a small tank, and the water can be a little bit wavy from time to time. So I added an RC delay on the output to relax the signal a bit. It helped, but is it better to place it after the buffer? (the buffer is there so the pump and valve controls does'nt disturb the opamp hysteresis).
Offline moffy
Re: RC delay after comparator or buffer?
« Reply #1 on: June 09, 2024, 03:03:23 pm »
It is kind of a '6 of one, half a dozen of another'(i.e. more or less the same) type of question, but I think I would prefer the filtering before the comparator.
Offline Benta
« Reply #2 on: June 09, 2024, 04:44:04 pm »
Drop the gates and place a leaky integrator before the comparator.
Online shapirus
  • Country: ua
« Reply #3 on: June 09, 2024, 04:59:13 pm »
One thing to note is that the -02 gates don't have Schmitt trigger inputs, so they aren't designed for slow input signal level transitions. A -14, -17, -132, etc. gate will be a better choice.
Another problem is that LM358 is an op amp and not a comparator. I'm not sure if using it as a comparator will create any issues, though, but it's not supposed to be used like this.
