I am working on a DIY 1000V differential probe project.
I have completed the first stage of the circuit and its simulation. The project is essentially based on the DP10013 model from Micsig. Using the DP10007 schematic that Dave released and all the photos I could find on the internet, I set up a simulation on Proteus and observed that my circuit appears to be working. Of course, I am sure I will encounter hundreds of problems in real life
As you know, these types of devices have an over-range indicator. However, I couldn’t fully understand Micsig’s circuit for this. I will also use a microcontroller in my project, just like Micsig did. I selected the 32-pin Puya (030) as the processor.
I always think of using comparators, but generally, all high-speed comparators are single-supply and quite expensive. Micsig, on the other hand, used a simple opamp (OPA2171) in their circuit.
Do you have any suggestions on this matter?
