Author Topic: Question on Linear Technology AN12.  (Read 1534 times)
Offline hamster_nzTopic starter
« on: October 27, 2018, 10:41:36 am »
I'm looking at the TXCO design in https://www.analog.com/media/en/technical-documentation/application-notes/an12fa.pdf, and see something I don't understand.
In figure 6, is the 100k resistor on the Collector of the transistor supposed to be there? (see attached image)
What does it do? On a breadboard it actually works of the collector is connected to 5V, but not with the 100k....
Offline Conrad Hoffman
    • The Messy Basement
Re: Question on Linear Technology AN12.
« Reply #1 on: October 27, 2018, 03:46:42 pm »
That almost has to be a typo. Probably wanted 100 ohms or so.
Online floobydust
« Reply #2 on: October 27, 2018, 05:29:06 pm »
Strange, it's 100R in the Oct. 1985 version with 30k/100k for the data slicer.
edit: From rare goldmine, 1990 Linear Applications Handbook, in a time before pdf's and the Internet became a thing, it is 100R with 100k/100k but 0.01uF for the data slicer.
Something is changing part values around, I've seen three different versions.
« Last Edit: October 27, 2018, 06:20:50 pm by floobydust »
Offline glarsson
« Reply #3 on: October 27, 2018, 06:46:36 pm »
Why is the AN calling it a TXCO? Also a typo or a different reality?
« Reply #4 on: October 27, 2018, 06:57:07 pm »
In the to left of the schematic there is a thermistor that generates a 0-4V signal that is used to nudge the XTALs frequency.
« Last Edit: October 27, 2018, 07:01:15 pm by hamster_nz »
« Reply #5 on: October 27, 2018, 06:59:14 pm »
Hummm... 100 ohm makes sense...
Thanks for checking this!
Offline glarsson
« Reply #6 on: October 27, 2018, 07:04:26 pm »
Yes, but that makes the design a TCXO, not a TXCO. Whatever that is.
« Reply #7 on: October 27, 2018, 09:13:41 pm »
Oh dear! I didn't see that...
Maybe they let an intern update the appnote? :)
