I hope this is the right place for this question. If not, please let me know where the correct place would be.
I have a circuit board that controls lighting for fish tanks - rather a complex system actually.
The board has an M48T12-150PC1 real-time clock with the ability to store programming where the clock is maintained through power cycles with an INTERNAL lithium-ion battery. However, the battery is only rated for 10 years and this board is at least 18 years old. Needless to say, it does not retain the settings through power cycles.
I was hoping that I could solder on an external battery and use it in place of the internal battery, but after looking at the datasheet, I do not think this is possible.
I am asking for confirmation from someone who is more practiced than I am with datasheets to confirm my conclusion.
The datasheet is attached and the info I am looking at specifically is on pages 2 and 3. VSS it says is ground (for whatever reason - not sure why they would label a ground as a voltage source, but I'm not an EE) ... and from what I am seeing, Vso is the positive side of the internal battery, but it has no pin accessible for an override battery ... at least that's the conclusion I came to.
So ultimately, it looks like my only option here it to replace this component because there does not seem to be a way to use an external battery with it and if someone can confirm that for me, I would be most grateful.
Thank you,
Mike
