Hi all
Been tasked with finding a connector series that will allow for a module to connect to a panel and also connect via a cable using the same connector.
So need a female panel socket, male plug, female plug, male panel socket.
With both panel sockets being able to mate.
Only need 5 pins, and ideally needs to be in the 10-20mm diameter range of size.
Also can not be like $20 per connector. Looking for something on the lower end of the price range.
Thanks
Jack
