I've got a chip and I want to just connect logic high to a pin, is there any issue with just connecting directly to Vcc, or is a current limiting resistor a good idea?
In this particular case I have some 245 bus transceivers and I'm setting the direction of each permanently by either connecting DIR to GND or Vcc. This all works fine, but I was wondering if this will increase current draw or potentially damage the IC by not having a resistor in-line?
Thanks!
