Author Topic: What is amount of current required for p-mosfet when load is not applied?  (Read 835 times)
Offline Sai tejaTopic starter
  • Country: in
Hello, I am using p-channel MOSFET(NTR4502PT1G) in my application in the configuration shown in the image. If 9 V input is absent, p-channel MOSFET (NTR4502PT1G) turns on, and battery power is supplied to entire system if on/off button is switched on.
I would like to know the amount of current drawn from the battery when on/off button is turned off, the 9V input is not connected to gate terminal of MOSFET and battery is connected to the source terminal.
Please help me in this regard.
Offline bson
None, because there's no closed circuit.
Offline Ian.M
The datasheet says under 100nA of gate-source leakage.   https://www.onsemi.com/pub/Collateral/NTR4502P-D.PDF page 2 near the top.
The battery's self-discharge will dominate  e.g an Energizer 522 PP3 9V alkaline is expected to loose 20% of its charge over its five year shelf life.   Its capacity is about 600mAH.
120mAH/43800H = 2.74uA equivalent self discharge current.
The following users thanked this post: Sai teja
