Author Topic: Protection from humidity and condensation  (Read 1001 times)
Offline girishvTopic starter
  • Country: in
« on: December 18, 2022, 01:58:48 pm »
I want to measure temperature and humidity in a refrigerator. I want to use a humidity sensor like Sensirion SHT30 series. I am going to use a thermistor glued to a piece of steel for thermal mass.
The board will be placed in a small enclosure with slots to facilitate air movement. How do I protect the board from humidity, condensation and probably occasional spills?
Online coromonadalix
Re: Protection from humidity and condensation
« Reply #1 on: December 19, 2022, 04:31:09 am »
you have some pcb coating products,  you can dip them or  spray them
https://www.techspray.com/the-essential-guide-to-conformal-coating
The following users thanked this post: girishv
Offline bidrohini
  • Country: bd
« Reply #2 on: December 20, 2022, 03:39:26 am »
I think you need to make an enclosure like this: https://www.instructables.com/Building-an-Electronics-Enclosure/
  • Country: in
« Reply #3 on: December 20, 2022, 07:32:17 am »
I will have a enclosure large enough to fit the PCB. I can't seal the enclosure as I am using a surface mount humidity sensor. I will go with conformal coating as suggested by @coromonadalix
Offline Miti
« Reply #4 on: December 20, 2022, 08:51:28 am »
I guess it’s common sense but I’ll say it anyway. Don’t coat the humidity sensor.
Fear does not stop death, it stops life.
  • Country: in
« Reply #5 on: December 20, 2022, 09:37:25 am »
No harm in saying it ;D
Of course, I will not coat. I am trying to figure out a way to cover the humidity sensor. I would appreciate very much any advice on that front.
Offline Miti
« Reply #6 on: December 20, 2022, 09:43:52 am »
Mask it with masking tape and spray, don’t dunk the board.
