Is there any overall write up or summary about the Yaigol project?
I am looking for something in the following structure:
1) Initial problem detected that seem to indicate a design issue
2) Investigation about the design issue
3) Confirmation about the actual design issue
4) Current impact of the design issue
5) Current firmware workaround for the design issue
6) Actual hardware fix for the design issue
7) Improved results after the design issue has been fixed in hardware
Scopes that are affected: Rigol DS1054Z, Rigol DS2072A?
That's a lot to expect for a $400 scope!
There are two of these threads running and, after reading both, I suspect there may be some slight issues at the edges. In other words, with stuff I am never going to use. So I simply don't care! Can I get 4 wiggles on the screen that bear some semblance to reality? Sure! And that's all I need.
There are about 4 people on the forum who are absolute Rigol haters. No other way to describe them. But here's the thing: They won't sell off their Rigol scopes and buy something better. They just continue to use the thing while simultaneously bashing it. What's the sense in that? They could dump the thing for $300 and spend the proceeds plus another $1000 or so and get a scope that's twice as good (maybe) at 3 times the price of the original Rigol.
Here's another thing: You aren't going to get a $10,000 scope for $400. If the minor (trivial) failings of the 1054Z will eventually cause you grief, buy something else. Don't even look at the 1054Z. Or any other Chinese scope, for that matter. And don't expect that Rigol will ever fix the bugs. That way you won't be disappointed when they don't.
It is what it is and it will never be any better than it is today. If you keep that in mind, you won't be disappointed. Or, throw in a whole lot more money and buy something better.
