Author Topic: Project Yaigol: Fixing Rigol scope design problems.  (Read 153751 times)
0 Members and 22 Guests are viewing this topic.
Offline kripton2035
Re: Project Yaigol: Fixing Rigol scope design problems.
« Reply #225 on: May 19, 2016, 09:42:11 am »
and as you are american, if you win the taxes only of the keysight makes the price of the rigol ... LOL...
Offline bitseeker
« Reply #226 on: May 19, 2016, 05:26:32 pm »
Yeah, spend a Rigol, get a Keysight. Sounds like a good deal to me. :-+
Offline Fungus
« Last Edit: May 22, 2016, 04:31:35 pm by Fungus »
Offline wraper
  • Country: lv
« Reply #228 on: May 25, 2016, 07:06:04 am »
Looks like Keysight engineers understand PLL design much better than Rigol engineers!  :popcorn:
https://www.eevblog.com/forum/testgear/agilent-dsox2024-won't-boot/
https://www.eevblog.com/forum/testgear/oh-no!-i'm-never-buying-any-agilent-keysight-equiment-ever-again!/
Of course they do. They detect if there is no PLL lock. Rigol just silently outputs the variable frequency jittery crap into the ADC clock.
Offline hendorog
« Reply #229 on: May 25, 2016, 07:20:19 am »
But it seems to still meet its specs? Are you saying it was over-engineered? :popcorn:
Offline wraper
  • Country: lv
« Reply #230 on: May 25, 2016, 07:30:41 am »
Who meet the specs, Rigol? Certainly was not the case For DS1054Z because it had apparent effects on the waveform captured. Until they firmware(ish) kinda "almost" fixed non locking PLL, almost because the clock still remained not that clean, and it's not certain if 100% of the scopes became good enough to not have visible issues. This varies from scope to scope and you don't know how bad your particular unit is.
As of Keysight, scope checks and informs you if PLL gone wrong, therefore you know when the scope cannot be trusted.
Offline hendorog
« Reply #231 on: May 25, 2016, 07:51:31 am »
It was discussed on page 4 of this thread - about DS2k not the earlier issue about DS1k. AFAIK no-one found any problem with the DS2k in operation. Doesn't that deserve some more scrutiny? How come it doesn't matter? Is it being hidden by the poor FFT?
I think the DS1k problem was only visible once the data was extracted from the scope and an FFT run outside the scope? Perhaps that is also the case here.
Offline wraper
  • Country: lv
« Reply #232 on: May 25, 2016, 07:59:10 am »
No, it was perfectly visible on the scope screen. Dave even made a video about this.
Offline hendorog
« Reply #233 on: May 25, 2016, 08:07:58 am »
Ah yeah, but that was fixed by a firmware update - I was talking about what was left after the firmware update. I'm trying to find it now...
Offline tautech
« Reply #234 on: May 25, 2016, 08:08:28 am »
You must have missed following this link in the OP:
https://www.eevblog.com/forum/blog/eevblog-683-rigol-ds1000z-ds2000-oscilloscope-jitter-problems/msg552777/#msg552777
Offline hendorog
« Reply #235 on: May 25, 2016, 08:15:17 am »
Yep but I believe also prior to the update which resolved it to the point where it behaved normally.
Buds investigation was on what was left behind after the update.
Offline tautech
« Reply #236 on: May 25, 2016, 08:26:08 am »
I ask you how can a FW update fix a PLL design error, it can't, it only masks the problems it creates.
Buds investigation follows on from what was discovered in the DS1054Z WITH a DS2072A and confirms there's been an error in design, so bad that the PLL manufacturers datasheets layout recommendations appear to have been totally ignored.
Look, all manufactures make mistakes and there's many examples in threads here, this is just another one.
Offline hendorog
« Reply #237 on: May 25, 2016, 08:35:51 am »
Yep a firmware upgrade _can_ resolve a PLL error. I know this because I just built one and the relationship between the physical components and the settings was important enough to make the difference between not locking, locking with massive spurs, and locking with minimal spurs. (that was the best I could do on that board because I ignored the manufacturers advice, new PCB on the way :) )
I completely agree with your second point - they screwed up. But Keysight screwed up too, the only difference was that they detected their screwup and charged $2k to fix it...
But my original point stands -  at least for the DS2k it actually doesn't seem to matter. No-one has yet been able to explain _why_ it doesn't matter.
Offline tautech
« Reply #238 on: May 25, 2016, 08:50:29 am »
Well we learn something every day....thanks.
Do consider sharing your Yaigol design *moment* in another thread, I'm sure we'll all learn from your experience.  ;)
But that's not over yet.....once the word get out more and other user/owners that have had to pay for the fix find out....shit anything could happen, court cases, recalls, hey it's all happened to manufacturers before.  :popcorn:
Offline wraper
  • Country: lv
« Reply #239 on: May 25, 2016, 08:59:13 am »
There is a big difference between screwed up design and faulty particular unit. Also, don't forget about that it is Brazil, prices will be 2x+ of the US.
After warranty has already expired.
Offline hendorog
« Reply #240 on: May 25, 2016, 09:12:19 am »
Yes I have been thinking about that. I probably will once the new board arrives and I can show some progress.
It was a bit of a journey which started at  'complete disaster' and made it to 'OMG it kinda works' :)
Agree, that one will be interesting to watch.
Offline hendorog
« Reply #241 on: May 25, 2016, 09:20:47 am »
Yep, but which one is it ??
[/quote]
Yes, but that is on a 2.8k scope. Which is not commensurate with an A brand supplier.
If you have to throw away your scope and buy a new one when it breaks then there is no point buying A brand gear.
Offline wraper
  • Country: lv
« Reply #242 on: May 25, 2016, 09:39:14 am »
Not $2.8k if bought in Brazil. You don't understand how bad it is. Even in EU which is not that bad at all, prices usually are much higher. Though often are comparable for Keysight particularly as for now, after EUR exchange rate started to suck a lot but Keysight pricing in EUR seems not changed much.
Translated from newark/element14 website http://www.newark.com/brazil-direct-ship
2- Taxes which focuses and how to calculate?
Import Tax: 60% of the Customs Valuation (Customs Value = the value of goods sum + shipping)
ICMS: on average 18%, varying according to the State
« Last Edit: May 25, 2016, 09:47:05 am by wraper »
Offline hendorog
« Reply #243 on: May 25, 2016, 10:12:10 am »
Wow, those taxes are really bad!!
We have 15% + ~$60 for most items I have imported, and I think that is too much.
Can't do much about exchange rate unfortunately. Our exchange rate was quite favourable against USD too, but now it is not good.
Offline Fungus
« Reply #244 on: May 25, 2016, 12:21:40 pm »
Warranty aside, this really looks like some sort of serious design defect. Keysight could be in big trouble if more people read this thread and say, "That happened to me, too!".
Offline wraper
  • Country: lv
« Reply #245 on: May 25, 2016, 12:50:43 pm »
Seriously? PLL fault was not a design defect. All it was unlucky to receive such a scope and not test it in reasonable time period. And WTF Keysight out of warranty discussion is doing in the Rigol tread.
« Last Edit: May 25, 2016, 12:52:26 pm by wraper »
Offline Fungus
« Reply #246 on: May 25, 2016, 01:04:47 pm »
The 'scope was tested, placed in storage for a while, then refused to boot.
If the firmware is somehow being corrupted (for whatever reason, including "putting it in storage for three months") then that's a design defect.
Keysight has already admitted they've changed the firmware in more recent models so it's easier to re-flash it if it fails. That sounds to me like they've seen a problem.
Offline wraper
  • Country: lv
« Reply #247 on: May 25, 2016, 01:12:48 pm »
Maybe you should read it one more time? His scope with no boot issue was replaced IIRC after about 2.5 years. He briefly tested the replacement and put it into storage. Then when 3 year warranty already passed, he started to use the scope, after 2 hour heat up he got PLL error. Now his scope fails after about 40 minutes. Nothing to do with no boot issue which BTW is honored with free repair even after warranty has ended.
Offline Fungus
« Reply #248 on: May 25, 2016, 01:28:34 pm »
Maybe I should, it's hard to remember which of all the failed Keysights 'we're actually talking about.
Offline wraper
  • Country: lv
« Reply #249 on: May 25, 2016, 04:38:37 pm »
:palm: Your will to bash everyone except holy Rigol is just amazing. I'm talking about The Keysight form Brazil (link you posted in this tread). Get your facts right, before blaming some manufacturer for commited crimes.
« Last Edit: May 25, 2016, 04:40:56 pm by wraper »
