Does anyone else think there should be a decoupling cap close to the power pin of the oscillator? Looks to me like there's a LC filter and a ferrite on the input of the regulator, as well as the usual big/small cap combo, but nothing on the load side. I see a little guy floating up there but not right next to the IC.
Unless the cap is on the bottom side, there seems to be vias for that there.
Granted, the thing is probably not drawing more than 10mA, but wouldn't it be best to knock out high frequency energy on the load side, rather than only on the input side of the regulator?
It might change nothing at all, but for a 1 cent part, I thought it was SOP to sprinkle power decoupling caps liberally. I mean you can always depopulate it after some empirical tweaking, no?
