Author Topic: project idea  (Read 1816 times)
Offline strawberryTopic starter
  • Country: lv
project idea
« on: October 23, 2022, 05:41:44 pm »
fast prototyping/learning kit
is it silly idea ?
Offline DC1MC
Re: project idea
« Reply #1 on: October 23, 2022, 05:48:23 pm »
is it silly idea ?
No, not silly at all, but it has to be better/different than the 38767 other existing fast prototyping/learning kits, that ranges from 8051 and 6802 to the latest multicore MCUs, with an enormous assortment of interfaces, "hats", displays and touch panels.
 Cheers,
 DC1MC
  • Country: lv
Re: project idea
« Reply #2 on: October 23, 2022, 06:29:12 pm »
was thinking about basic stuff first . OP amps, resistors ...
Could be didital circuits as well, including MCUs
32768 ?
Offline DC1MC
Re: project idea
« Reply #3 on: October 23, 2022, 06:41:19 pm »
Some per-existing stuff:
https://download.mikroe.com/documents/specials/educational/aslk-pro/aslk-pro-manual-v103.pdf
https://www.digikey.com/en/resources/edu/harvard-lab-kit
https://www.analog.com/en/education/courses-and-tutorials/active-learning-module.html
https://de.rs-online.com/web/p/analoge-entwicklungstools/8904008
https://university.ti.com/en/faculty/teaching-materials-and-classroom-resources/ti-based-teaching-kits-for-analog-and-power-design
https://theelectronics.shop/product/edubit-learning-project-kit-for-microbit/
plus the rest until 30K, now with more Arduino, RPi and Nucleo  ;D
As I've said, the idea has to be REALLY original and affordable to compete with the existing offers. Also no youngster that I know of wants to touch anything related to electronics, all they want is to do some killer app, magic SaaS, next Twitter or something to get rich like their idol Zucky, they say that whatever actual stuff they'll design will be copied and sold by Chinese in no time. can't really fault them, this is exactly what it happens :(.
 Cheers,
 DC1MC
  • Country: lv
Re: project idea
« Reply #5 on: October 23, 2022, 07:37:54 pm »
not a toy , not like TI pro
to reduce soldering effort and messy wire clutters found on breadboards
maybe useful as arduino
some are fighting back china copy on amazon
Offline tomgat
Re: project idea
« Reply #6 on: October 23, 2022, 07:57:46 pm »
is it silly idea ?
Not at all.  Even the biggest development projects go a similar route.  On the bigger projects, its very common to have several tables full of test boards all wired together demonstrating the system fully running knowing it will eventually be condensed down to one final board design.  It not only allows the software developers to work in parallel, but also helps better refine the hardware design.
Also, in general, software takes longer to develop than hardware, and many times you change the hardware design as you know more of what your wanting to build.  My suggestion is to start with some mikroe click boards (Adafruit and SparkFun make great boards too but have a much more limited catalog) to give yourself time to write your software, talk to the intended end user, and further refine the idea.
After you know what you want and have fully flushed out the project idea, making the final hardware is actually the easy part.
« Last Edit: October 23, 2022, 08:01:39 pm by tomgat »
Offline DavidAlfa
Re: project idea
« Reply #7 on: October 23, 2022, 10:00:43 pm »
Years ago, before all this electronics boom, I thought on making a board full of pci connectors, all pins connected together in a bus, then making a master card (CPU, Pic, avr, whatever) and a bunch of prototyping PCBs where you would solder all kind of stuff, having all signals available there to use, avoiding lengthy messy wires everywhere and allowing quick removal or addition you would insert any card in any slot indifferently.
The idea was to avoid the usual problems in breadboards and to easily add and removed modules.
Well, just like today with Arduino hats, but better.
However back then PCBs were no close as cheap as now and didn't pass the idea stage.
Offline Vovk_Z
  • Country: ua
Re: project idea
« Reply #8 on: October 24, 2022, 08:46:36 am »
32768 ?
- quite dangerous number. I'm not sure what will haplen if we add one more .
Offline ledtester
Re: project idea
« Reply #9 on: October 24, 2022, 09:33:21 am »
is it silly idea ?
Something like this?
Offline pcprogrammer
Re: project idea
« Reply #10 on: October 24, 2022, 09:47:50 am »
Nice test lab :)
But strawberry has an idea to get rid of the messy wires, and with yours I can see it getting very messy :-DD
  • Country: lv
Re: project idea
« Reply #11 on: October 24, 2022, 06:52:20 pm »
diff amp pcb
Offline bidrohini
  • Country: bd
Re: project idea
« Reply #12 on: October 26, 2022, 10:35:18 am »
Here is also an Amplifier PCB that may interest you.
https://www.pcbway.com/project/shareproject/LM386_AMPLIFIER_PCB.html
This is based on LM386 OPAMP. If you see the datasheet of this OPAMP, you'll find more designs with different gains.
Online RoGeorge
Re: project idea
« Reply #13 on: October 26, 2022, 10:41:37 am »
The idea is attractive (for enthusiasts only), but I doubt it would be profitable.  Try it, but don't bet too much in advance.
