Interesting that with a perfect inductor with no resistance and no core losses, when switched on at the zero crossing the current will always remain one side of zero. It will continually rise to a peak value and fall to zero but never reverse even though the AC supply does.
It suddenly occurred to me, provided you could find a perfect inductor you could make a DC power supply from an AC source without needing a rectifier diode! LOL
Eidt -> seems that would only work if you needed a supply that would supply current only, at zero volts output...
