Hi
I am using MAX11060 as a adc for my DC Monitoring system. However FAULT and OVRFLW pin are always go low as the chip startup. That mean voltage between AIN+ and AIN- are exceed the fault threshold. But Even if all AIN+- pins are leave floating. FAULT and OVRFLW still go low and DRDYOUT never goes low too.
Anyway I can communicate with this chip through SPI and I can read or write any register. That mean the chip still working.
I'm setting XTALEN bit to 1 and leave everything to default.
I'm trying to measure voltage between AIN+ and AIN-. When the chip is not powered. I can measure the voltage as same as the the voltage source (around 0.124 V) but when chip is powered the voltage between AIN+ and AIN- were dropped to 0.034V and I think because of fault protection circuit in the chip. (this happen whatever I set FAULTDIS in configuration register to 1 or 0)
I read all of the data sheet and in page 15 said that
When the analog input voltage changes between the ADC full scale and the fault threshold faster than the latency of the converter, OVRFLW goes low with the FAULT output. OVRFLW remains invalid until a valid clock frequency is available at XIN.
So I think that it must be something wrong with my Crystal or Capacitor Coupling so I change it from 20pF to 18pF and 10pF and I still have no luck.
Here is my schematic
ADC Datasheet -
https://datasheets.maximintegrated.com/en/ds/MAX11040K-MAX11060.pdf
