Author Topic: 6 Series LED circuit by Fredzislaw100  (Read 4109 times)
Offline EEVblogTopic starter
« on: May 02, 2012, 01:32:59 pm »
He has a new series LED circuit puzzler:
Dave.
HLA-27b
  • Guest
Re: 6 Series LED circuit by Fredzislaw100
« Reply #1 on: May 02, 2012, 02:31:18 pm »
Naah...just simple magic   ???
or something based on standing waves with oscillator (or noise source) hidden in the battery and L-C components hidden inside the switches.
Offline McMonster
    • McMonster's blog
« Reply #2 on: May 02, 2012, 09:10:12 pm »
It's not that interesting since he revealed how the first circuit really worked. But I think this video is also made to troll people. But this time by the way he solders those LEDs. :P
Offline bogdan546
« Reply #3 on: May 04, 2012, 11:58:05 am »
Something like this
Offline Psi
« Reply #4 on: May 04, 2012, 12:14:40 pm »
If i was going to make it i'd probably put one of those 2x2mm Atmel microcontrollers under each led and inside each switch.  Switch --> led communication could be done with led pulses too short to be visible.
In fact, a tiny micro doing software definition radio transmission could make some interesting layout possible
« Last Edit: May 04, 2012, 12:19:01 pm by Psi »
