Author Topic: True Multi-meters needs true cables !!  (Read 18983 times)
Offline zaoka
Re: True Multi-meters needs true cables !!
« Reply #25 on: April 29, 2011, 11:32:41 pm »
Kiriakos-GR
What about "take it a part"? :)))
Lets see how is the quality compared to Simpson and Triplett :)))
Offline Kiriakos-GRTopic starter
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« Reply #26 on: April 30, 2011, 11:58:38 am »
Kiriakos-GR
I was hopping , that after posting this thread,
some one would help me , with some tips about how it opens.
I am aware that even the black boxe of an airplane , they do have an way, so to open them.  :D
But the one who will do it , has the knowledge to do it .
With out such information at hand , I do not take the risk to find out how it opens.
From the pictures that I posted , it does not have bottom screws.
The top screws are just for the range switch and front panel ,
and even from there you have no access so to see even the PCB .
My guessing are that the top half casing , with the bottom half casing, are hard pressed .
I will post in few minutes some more pictures , about this " problem "
  • Country: gr
  • User is banned.
« Reply #27 on: April 30, 2011, 01:40:41 pm »
Ok here is as far that I would go for now .  :)
I managed to pull out the analog organ from the body .
I had select nine pictures full resolution ( no editing ..)
Inside there is dual PCB , the bottom PCB handles the relay,
plus it is used for all the big parts ,
I could describe it as an high amperes highway , that connects to the banana plugs.
The top PCB has the software (  ;D )  , small transistors and diodes. ( ohms range + voltage)
Both PCB looks to me in top shape ,
what looks amazing as detail , are that even the curves of the leads, in the resistors,
they all have the same shape, they must had make an special tool, just for that.
I noticed inside few particles of dust , no oxidation or damage in anything .
I found some pressure points at the top cover, that probably releases the top cover , but I will not try to open them.
Because there is also similar release points at the bottom,
that looks that you have to use an specific tool for those ,
shaped as large fork , and probably only the factory has or had, one of those.
This shaped as fork - key ... must look similar with the special ones for the car stereos ( and usually comes with them) ( easy installation and removal)
The analog organ ( meter) has an transparent window at the bottom of it.
Just an production code , and no other info.
There is three copper plates at the left , I think that is the amperes shunt , I could be wrong too.
For an complete tear down you need to know all the steps , like one - two - three ,
looks as very complex design even to me .
That I have an good experience from hundreds but modern, devices.
And finally looks more modern than those AVO  ;D
« Last Edit: April 30, 2011, 01:46:07 pm by Kiriakos-GR »
  • Country: gr
  • User is banned.
« Reply #28 on: May 03, 2011, 03:29:19 pm »
It looks that we had lost the fun club of those oldies   :)
And so no one noticed in the last picture,
that all the PCB of this Metrawatt , are totally silver plated.
Silver is one step behind from gold , but I am still happy ,
that is not an common solder plated , like the many cheapo ones , out there .  ;)
Offline tekfan
  • Country: si
« Reply #29 on: May 03, 2011, 04:27:45 pm »
Wow! That's beutiful build wuality!
Do I se a current transformer below the board?
One can never have enough oscilloscopes.
Offline Ernie Milko
« Reply #30 on: May 03, 2011, 04:50:56 pm »
Still mickey mouse compared to an AVO  ;D
  • Country: gr
  • User is banned.
« Reply #31 on: May 03, 2011, 06:21:02 pm »
Aaaaaaaa   ;D  I was expecting such an torpedo ,
the only thing that I was not aware , was the sender ..  :D
