Hello,
I am trying to let 3D Glasses with DLP Link react to a bright led flash that is triggered by the VGA Vsync signal. It pulses as intended. The strange thing is, it does not shutter, even when getting close. I tried different Vsync frequencies (60hz, 100hz and 120hz). Last of the 2 should definitely do the trick, since the frequency is officially supported. To verify the signal I hooked up a wide range speaker. It definitely works putting out nice squares as intendet (tested in simulation). My mobile camera proofes the signal is correct, since the brightnes also hard cuts off. (Using exposure timing to verify frequency and waveform)
Hm.... So now I do not know what should work. The manual states, that some 50/60hz lights will false trigger the glasses, so it should actually not be toooo picky about the signal. Tested on my 4W chinese LED which also flickers at 100hz (50hz 230V in germany) it also does not darken the "lenses".
Since I cannot find ANY information on how this works, I have no clue what to do. I definitely need the glasses to shutter at the Vsync frequency.
But what timing does the white flash need to have? If I am not wrong, the Vsync pulse is 64us long. This seems like a nice short, bright flash. What is possibly wrong with this technology? o.O
