Again at the bench! Thank you guys for discussing the problematic in such detail. Although I do not understand everything now, I might in the future, when I will grow up and be like you guys
I might have not specified in the beginning, that the whole "supply madness" is a part of my project designing a usable "high voltage" regulated supply 0-400V 0-300mA. There aren't many of those real usable designs on the web, so I accepted the challenge to make one. Sorry for not being clear from the beginning, but originally I have asked due to my colleagues concerns about the topology might be inherently unstable - which I am glad is not.
I do understand, that there are many ways to design such supply, but please respect this is my first (or not exactly first, but first which might work) trial to make such PSU, so some compromises have to be done
salbayeng: Thank you for the tip to use cascode! I might try that one in the next better prototype. Gate-Source zener diode will also be added, together with other at least two protection diodes in the circuit (the schematics posted here are nowhere near complete, more like describing the principles of the regulation loop)
Kleinstein: Yes, current limiting is what I need to do next. Or before I do, I need to think out how to merge the voltage and current control loops.
Could you please help me evaluate my ideas for merging the control loops?
One of the usual ideas behind current limiting seen in many other circuits is that the current regulator opamp drags the voltage regulator reference input down, through a diode. However I can't use that, as I would need the opamps output to go negative (one diode drop) to be able to drag the ref voltage down to zero.
The idea behind using the inverting amp as a voltage divider was that only unipolar supply voltage is required. Therefore I cannot use the "ref voltage clamp" technique, as I can't go negative, as described above.
What I thought was I could sum the opamp outputs through diodes and "hang" the gate with a resistor (or possibly current source) up to the positive supply. The schematic is below, image A. This circuit has a dangerous flaw: To be able to control the mosfet fast enough, the source current through Rg might be high (some tens mA). That means the diode voltage drop will be quite high and also the opamp output saturation voltage adds up. This means the gate voltage cannot be brought directly to zero, but only about a volt or so. (one diode drop + opamp sat.)
I think better solution might be to use the B variant on the schematic below. The diode drop is compensated by the Vbe of the transistor. So when the cathode of D1 or D2 is at GND level, the emitter will be very near GND too. Also the current through the diode and opamps output will be low, resulting in low saturation voltage and the widest range of gate control voltage down to almost zero. The emitter resistor Re might be also replaced by a current sink: A simple two transistor one (adding few hundred mV of drop) or likely just JFET as a current sink?
What do you think about this idea? Is it a good enough solution or are there similarly simple but better ones? How will this influence the control loops?
Thank you!
Yan
//EDIT: Just a thought: A diode accross E-B of the emitter follower might speed up gate discharge, as the opamp sink current ant I(Re) current will sum.
