I am at the point where I am actually going to construct the Buck portion.
Would there be any negative effects of leaving this cap stage in there?
Would there be any positive effects?
In this particular application the main downside of leaving the buck-output/bridge-input capacitor in is the cost/volume of such, though it won't be anywhere near as costly/big as the input capacitor for a width-modulated full bridge (because each bridge leg will be operated very close to 50% duty so it will draw a nearly constant current from the capacitor). Otherwise, there are two other major downsides to the buck voltage-fed bridge, of which only one is relevant here: 1) no intrinsic tolerance of a short on the secondary (irrelevant because the C-W multiplier presents a high impedance load even with its output shorted); much higher turn-on loss in the bridge switches due to bridge input capacitor ensuring voltage remains nearly constant across the switches during the entire turn-on transition, exacerbated by reverse recovery of the anti-parallel diodes because during the dead-time some or all of the primary current will have transitioned to them.
A 10+ stage multiplier on the other side of the transformer isn't exactly a large value output cap..
And most importantly can you be more specific with the overlap?
Hmmm... a 10 stage C-W multiplier is going to have terrible voltage sag and very high ripple under load. Dave, our fearless leader here, did a very good video on C-W multipliers and I encourage you to pay particular attention to the last few minutes where he tests a 4 stage (x8) multiplier under load:
(I guess youtube embedding tags don't work here?) [edit - I guess it does; didn't show up as embedded when I previewed my post...]
Remember, there's no such thing as a free lunch so if you want, say, 150kV at 1A from a 10 stage multiplier you will need to theoretically feed
20A at 7.5kV into the first stage (realistically you will have to feed a lot more that 7.5kV because of voltage sag). You can reduce voltage sag by making the capacitors in the first stage n times bigger than the capacitors in the final stage, where n is the number of stages (edit: and making the capacitors in the 2nd stage n-1 times bigger, etc.), and by using a center-tapped secondary and mirroring a second C-W multiplier on the other leg, which turns this into a full-wave multiplier with the center-tap as the negative output reference. Actually, I should emphasize this much more clearly: you pretty much have to use a full wave multiplier at this power level.
The overlap time for the bridge switches in the current-fed version is not too critical. A somewhat fast-n-loose approach which nevertheless tends to work well with IGBTs (not MOSFETs!) is to simply drive each bridge leg with a straight 50% duty complementary square wave, relying on the turn-off delay time of the IGBTs to ensure there is some overlap. There is a dedicated PWM controller IC for buck voltage- or current-fed
push-pull converters, the LM5041, which lets you select between overlap or dead-time of the push-pull switches; it is very easy to adapt this IC to a full-bridge converter.
edits - additional info; removed erroneous reference to poor transformer utilization (due to my misinterpretation of the half-wave ripple from a C-W multiplier automatically meaning it was a half-wave rectifier, though it is actually full-wave).
