Author Topic: Huntron 1005 Oscillator can we find the problem?  (Read 1034 times)
Offline sampler1Topic starter
« on: August 19, 2021, 07:56:33 pm »
Hi All,
like many the Oscillator died in my Huntron 1005B. as you know they are no where to be found. I came across the old kit schematic and figured I would try and build one. My 1st problem was IC1 and IC2 as they are not identified in the original schematic. I was told by some members to try LM336.
At this point I have made the PCB but its a no go. I seem to be able to adjust the gain a bit but it seems to go into clipping very fast. The frequency does not adjust at all. So here I am bringing it to the pros. It should produce 80Hz at 10VPP.
Any suggestions or see any errors?
Best regards
" alt="" class="bbc_img" />1248243-1
“Electronic devices are powered by white smoke. When smoke goes out, device is dead.”
Offline kripton2035
Re: Huntron 1005 Oscillator can we find the problem?
« Reply #1 on: August 19, 2021, 08:08:04 pm »
as I read the kit schematic, it seems to me that it is written 1/2 1458 beside the two aop ?
so it should be a LM1458, obsolete, or its actual equivalent MC1458 ?
and the LM336 is a voltage reference, not an AOP !
even the LM356 is a single AOP ...
Offline floobydust
« Reply #2 on: August 19, 2021, 08:32:05 pm »
In your schematic, I see D4 backwards. Otherwise the circuit remake looks reasonable to me, assuming you are using 1458.
« Reply #3 on: August 19, 2021, 10:24:45 pm »
I have many LM1458's in stock and the Lm336 are for IC1 and Ic2
« Reply #4 on: August 19, 2021, 10:25:49 pm »
OMG D4 is backwards.. Ill check that out tomorrow and report. Thanks!
Offline kripton2035
« Reply #5 on: August 20, 2021, 06:49:48 am »
oups should have read better !
